DKRacingFan
Jun 18, 2019Aspirant
Use Netgear C3700 N600 as Modem Only
Hello! I am planning to upgrade to a different wifi router in the future. Can I use this modem/router as a modem only and connect a router to it? Thanks! I heard that the C3700/N300 doesen't, but i...
- Jun 18, 2019
When the C3700 is fully bridged, then the R6700 router will work with it.
DKRacingFan
Maybe I should rephrase a bit.
I got a modem router and wonder if it will work with the Netgear R6700 Nighthawk AC1750 Dual Band Smart Wifi Router My router https://www.netgear.com/home/products/networking/cable-modems-routers/C3700.aspx I
have seen here that I can use my current router the modem router as a modem only so I think it should work? I have seen it in my settings on my router. https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
Jun 18, 2019Guru - Experienced User
