Laxmikanth's avatar
Laxmikanth
Follower
Sep 17, 2019
Use of C7000v2 in India which is purchased in the US
Hi,
I have purchased "NETGEAR Nighthawk WiFi Cable Modem Router Combo (24x8) AC1900 DOCSIS 3.0" in the US and have been using it for the Xfinity/Comcast. I am moving to India and would like to know if I can use the same modem router in India for the cable wifi connection.
Thanks
  • FURRYe38's avatar
    You would have to ask the ISP in India if they support this model modem on there network.
  • Hi,
    did it worked in India?
    I have same model and i will be going back to India soon.
    • FURRYe38's avatar
      suyash271 wrote:
      Hi,
