mark45865
Nov 08, 2023Follower
Used CM1150v no mac address
I bought a used 1150v from ebay, no bottom mount, and the only thing listed in the modem is the serial number... no mac address anywhere on any screen...
Kitsap
Nov 08, 2023Master
mark45865 wrote:I bought a used 1150v from ebay, no bottom mount, and the only thing listed in the modem is the serial number... no mac address anywhere on any screen...
Log in to the user interface. Go to the Advanced Tab.
Select Administration -> Modem Status and a small window will open on the right. That window has a scroll bar. The MAC address is the last item at the bottom of the scroll. It is labeled CM MAC.
