Jab20
Jul 16, 2020Aspirant
Used CM600 Setup Question
Hello! I’ve got a quick question about a CM600 I sold recently. I did a factory reset before I shipped it out and instructed them to do the same, but they claim that xfinity is needing some of my old ...
- Jul 16, 2020
Are you on XF or a different ISP? If the same ISP, then they maybe seeing the MAC address listed under your account information still.This would need to be removed.
Yes, a factory reset would blow away any configurations on the CM modem. Which would only be the admin and password configurations.
I would make sure that XF removed the MAC address from your account if your with XF. If not, then XF shouldn't be asking you for any info. They should be associacting with there services under the new owners account.
Jab20
WiFi name and password, but it doesn’t have WiFi.... I think admin is unchangeable and password resets with a hard reboot
Jab20
It really should be just a yes or no, would a factory reboot reset the machine to where their provider should have no problem setting it up.
- FURRYe38Jul 16, 2020Guru - Experienced User
