jazzgal
Apr 16, 2024Aspirant
using 2.4GHz band
I am attempting to connect a nanny cam to my network; my router is a C7100V with dual bands. The camera requires a 2.4 GHz frequency, but I can't seem to connect to my network. How can I confirm th...
Apr 16, 2024Guru - Experienced User
I would log into the modems web page and check to see if Smart Connect is enabled or disabled. Disable Smart Connect if seen there then use the 2.4Ghz SSID name to connect your devices to the modem. Log in at 192.168.1.1 in a web browser on any PC or laptop.
jazzgal
Thank you for the very helpful reply, but I don't see Smart Connect anywhere.
