jazzgal
Apr 16, 2024Aspirant
using 2.4GHz band
I am attempting to connect a nanny cam to my network; my router is a C7100V with dual bands. The camera requires a 2.4 GHz frequency, but I can't seem to connect to my network. How can I confirm th...
jazzgal
Thank you for the very helpful reply, but I don't see Smart Connect anywhere.
Apr 16, 2024Guru - Experienced User
Ok. Should have separate WiFi SSID names for each frequency then. Just use the one for the 2.4Ghz wifi for your devices. You can give a new name to each frequency if you like and it's recommended. Can be most anything. Make it intuitive and fun.
