PeterTheSbam
Mar 23, 2020Aspirant
Using a Tesltra Gateway Max modem on iiNET NBN
I have a C6300BD-1TLAUS cable modem, provided by Telstra (an ISP). I want to switch over the the National Broadband Network (NBN), with a different provider. With the NBN, the NBN Co provides a cab...
Mar 24, 2020Guru - Experienced User
You'll need to check with your new ISP to see if it's supported on there network. If not, then you don't be able to use the C modem.
