bryanbdp's avatar
bryanbdp
Using AP mode on CAX-30
I just got Frontier cable to my house, which uses an eero network connector and router.
I would like to use my CAX-30 in my detached garage to use it as an access point.
I would connect it with a cat6 cable and give the wifi a unique name to avoid interference with main router. I want to be able to login to CAX-30 with wifi, and access the internet and other computers on my private network. will this work? If not, how do I set this up?
  • michaelkenward's avatar
    michaelkenward
    Cable modems do not come with "AP mode" option. No WAN (Internet) port on the back.
    To see what you can do with it, get the manual.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    For more on this device, try the appropriate section:
    Cable Modems & Gateways - NETGEAR Communities
    • bryanbdp's avatar
      bryanbdp
      According to manual, it does have AP mode but not bridge mode. Just don't fully understand how AP mode works
      • plemans's avatar
        where are you seeing that?
        Because like michaelkenward says, there isn't a ap/bridge mode.
        It either has modem/router or modem mode. that's it.
