lcasta
Jun 28, 2018Tutor
Using c6300 in modem only mode
I recently turned off the router on my C6300 to use it in conjunction with an eero system. I had a problem with double NAT because the C6300 was one network and the eero was another. I also had probl...
- Jun 28, 2018
> Short of resetting the modem-router to the factory settings, is there
> any way for me to reverse what I have done?
Did you try "192.168.100.1" in your web browser?
> to access the modem in Bridge mode, you need to set static IP on your
> laptop in 192.168.100.x subnet and access 192.168.100.1. (this is
> standard process on all DOCSIS based devices).
I thought that you could get away without fiddling with your
computer's IP configuration, but, if it doesn't work the easy way, then
I'd try the hard way. (Or just do the reset.)
> I think what I needed to do [...]
Yup.
> [...] If I disable the radios in the Netgear router, they won't
> compete with the eero wifi.
"Compete" or "supplement"? It's not obvious to me that having more
wireless access points would be a bad thing.
> [...] So far, I haven't found a way to go back into the Netgear setup
> screens to change the modem-only setting on the Router Mode page. [...]
"192.168.100.1"?
> [...] I assume that, if the Netgear is set up as a router and the eero
> is set up as a bridge, the Netgear will provide the IP addresses for
> everything connected to the eero as well as anything connected to the
> Netgear directly through its ethernet ports. Is that correct?
That's the idea.
> [...] What I'm trying to accomplish is have one network that all my
> devices can connect to and to avoid double NATs. [...]
One router (doing NAT, DHCP, port-forwarding, ...), multiple wireless
access points -- One big (extended) LAN. Sounds glorious, doesn't it?
vkdelta
Jun 28, 2018NETGEAR Employee Retired
in Bridge mode, there is ONLY ONE PUBLIC IP. Thats why ONLY ONE ethernet port works.
to access the modem in Bridge mode, you need to set static IP on your laptop in 192.168.100.x subnet and access 192.168.100.1. (this is standard process on all DOCSIS based devices).
also, everytime you connect/disconnect new devices on LAN side, Please reboot the modem. Modems learn MAC-ADDRESS and use it to fill the MAX_CPE table. when you connect modem to ISP, ISP typically set MAX_CPE=1 (which means only device can be connected on the LAN side).
- antinodeJun 28, 2018Guru
> [...] I just thought I could go back to the same dialogue screen and
> turn it back on if something went awry. But, now it doesn't seem you
> can. [...]
Are you talking about a "dialogue screen" on an eero or on the C6300?
What, exactly, did you try to do? What, exactly, happened when you
tried to do it? "it doesn't seem you can" is not a useful problem
description.
If you configure any router as a wireless access point, then it
ceases to have separate WAN and LAN interfaces, and becomes all-LAN. At
that point, it typically gets a new LAN IP address, which would be
specified by either the administrator or the (DHCP server on the) main
router. That normally means that its administrative web site must be
accessed at its new LAN IP address. If that was assigned using DHCP,
then you may need to scan some kind of Attached Devices or DHCP Clients
report on the main router to see which adderess it gave to the
router-as-WAP.
> [...] I included a screen shot of the network settings om my Mac [...]
That "72.219.x.y" address is a public address, which suggests that
your Mac is connected to your ISP without a router in between. If you
can reach the C6300 at "192.168.100.1", then you should be able to set
it back to modem+router mode without a settings reset. - lcastaJun 28, 2018Tutor
Thanks. That explains what's happening.
Short of resetting the modem-router to the factory settings, is there any way for me to reverse what I have done?
I think what I needed to do was leave the router functioning and just disable the two wifi radios on the Wireless Setup page. Eero allows you to set its equipment in the bridge mode and then I imagine putting the eero network into bridge mode will extend the Netgear network without creating a separate network. If I disable the radios in the Netgear router, they won't compete with the eero wifi. So far, I haven't found a way to go back into the Netgear setup screens to change the modem-only setting on the Router Mode page. I assume that, if the Netgear is set up as a router and the eero is set up as a bridge, the Netgear will provide the IP addresses for everything connected to the eero as well as anything connected to the Netgear directly through its ethernet ports. Is that correct? What I'm trying to accomplish is have one network that all my devices can connect to and to avoid double NATs. Let me know your thoughts. Thanks again.
Yup.
"192.168.100.1"?
That's the idea.
access points -- One big (extended) LAN. Sounds glorious, doesn't it?- lcastaJun 29, 2018Tutor
Thanks. That seems to be the key. I kept trying 192.168.0.1 which is what I generally use to access the router-modem. I didn't notice that you and another person were suggesting 192.168.100.1. Everything is working now. And I have eero in bridge mode. Can I uncheck the boxes for Enable SSID Broadcast on the Wireless Setup page to keep some of my devices from trying to log into the Netgear router rather than the eero network which is accessible anywhere in my house? The signal strength on the Netgear is quite weak in some parts of my home bnut if I go from one part of my house to another the device such as an iPad is still logged on to the Netgear. Thanks once again.
