arthurdelrosari
Jan 30, 2019Follower
Using C6300 in Router-Only Mode?
My C6300 "died". The internet from the coaxial cable is working as per Comcast's technician, but the unit is not able to see the signal and not able to provide internet connection (both wired and wir...
Nodism1125
Jan 30, 2019NETGEAR Expert
Hi arthurdelrosari,
There is no way to setup the Cable modem router act as router. The unit doesn't have WAN port where you will connect the new modem.
You can use the modem/router as Access Point only.
- antinodeJan 30, 2019Guru
