Eames's avatar
Eames
Tutor
Feb 06, 2024
Using CM 1200, Four WAN IP Addresses, Router configuration for each WAN IP?
I have an ISP with four WAN IPs. I have a CM1200 to deploy each IP. I have two RAX30 routers to seek to have an external IP go to an internal LAN IP address. The first router, with IP of 10.1.1.1, the gateway, works and directs external IP to the internal IP.
How do I configure the second router? If I configure as 10.1.1.2, this receives traffic direct to the second WAN address (it shows in logs), however, it is never received on the internal, LAN, IP specified. Is not in log traffic.
I have talked with support with no help.
Either external WAN IP works as long as the internal router is 10.1.1.1, but no configuration seems to allow them to co-exist.
Please advise. I can't be the first to want to configure multiple routers to work with the CM 1200.
  • FURRYe38's avatar
    Power OFF the CM modem.
    I recommend using the default IP address of the 1st router to use the 192.168.1.1 subnet schema.
    I recommend using the default IP address of the 2nd router to use the 192.168.2.1 subnet schema.
    I recommend using the default IP address of the 3rd router to use the 192.168.3.1 subnet schema.
    I recommend using the default IP address of the 4th router to use the 192.168.4.1 subnet schema.
    Once these are each on each router. Power them all OFF.
    Connect them to the back of the CM modem starting with port #1.
    Once all connected, power ON the CM modem. Give about 30 seconds, then power on the 1st router, then power ON the 2nd router, and so on and so on.
    Be sure your ISP supports giving out multiple WAN IP addresses to one modem. Most do not. Mine I can get 3.
    • Eames's avatar
      Eames
      Tutor
      I do indeed have 4 IP's. This configuration looks like it would work, however, what are the appropriate Subnet maskes? 255.255.0.0? And how do I get to the appropriate LAN devices?
      We have to share LAN servers. We are a small consulting business. Servers can have multiple addresses, but what gateway IP do I use on the servers?
      We used to have ways to create static routes to other networks, but I don't see that in the documentation and I am not network literate, but able to follow directions.
      I thought the CM 1200 documentation would show.
      • FURRYe38's avatar
        Use default SNM, 255.255.255.0
        Gateway IP would be same as IP addresses of the router as I suggested for each.
        The CM modem is just that, a modem only, no routing here. Any static routes would be made on the wifi routers themselves. I'm not experienced in those features so you may need to see help for static routes online.
