djinn13
Mar 11, 2020Aspirant
using GS108Tv2 to trunk MB8600 and connect ac1750 to switch
i just want to know if this is possible and or a smart config B8600 trunked with GS108t then connect AC1750 to the switch. have lan behind the router. I would have nothing else between the swi...
- Mar 11, 2020
These are more than aged routers, AFAIK they are suporting WAN or business continuity (fail-over) or load balancing between two independent Internet connections. Not aware there is WAN aggregation support.
Netgear offers some consumer routers, resp. the firmware was enhanced to extend the WAN interface by allowing the aggregation with an additional dedicated LAN port. Some examles are the RAX80/RAX75 -> https://kb.netgear.com/000060393/How-do-I-set-up-Ethernet-port-aggregation-between-my-NETGEAR-Nighthawk-Multi-gig-Speed-Cable-Modem-and-my-NETGEAR-Nighthawk-AX8-router and the RAX200 https://kb.netgear.com/000060873/How-do-I-set-up-WAN-aggregation-on-my-NETGEAR-Nighthawk-Tri-Band-AX12-router
Please understand that "AC1750" does not say much about the hardware or the model - this is just some WiFi technology standard and a sum of theoretical max link speed achieveable.
schumaku
Mar 11, 2020Guru - Experienced User
djinn13 wrote:B8600 trunked with GS108t then connect AC1750 to the switch. have lan behind the router.
Sorry, must have missed this router. Creating a trunk / aggregation between the modem and a Gigabit switch does not make any sense - because the router will be connected as a single GbE device only.
The set-up could make sense if using a router supporting a MultiGig or 10GbE WAN/Internet port, and a switch also supporting a MultiGig/GbE to provide the additional bandwidth.
djinn13
so what you are saying is that i should have bought something like this instead?
Cisco Small Business RV320-K9-NA Dual Gigabit WAN VPN Routers
or something of the like?
- schumakuMar 11, 2020Guru - Experienced User
Please understand that "AC1750" does not say much about the hardware or the model - this is just some WiFi technology standard and a sum of theoretical max link speed achieveable.- djinn13Mar 11, 2020Aspirant
i just tossed it up as an example.
thank you for you help i now know what i have to do.
