SushiPragmatic
Apr 14, 2020Tutor
Using modem CM1000 with firmware V6.01.02 and Cox ISP?
I currently have a CM1000 and firmware V6.01.02 was deployed upon activation with my ISP, Comcast. I want to upgrade to a better modem and give my current CM1000 to a family member but they have Cox ...
Apr 15, 2020Guru - Experienced User
SushiPragmatic wrote:I currently have a CM1000 and firmware V6.01.02 was deployed upon activation with my ISP, Comcast. I want to upgrade to a better modem and give my current CM1000 to a family member but they have Cox as their ISP which, according to this Netgear Support document, approves firmware V3.01.04.
Will my family member be able to use a CM1000 with firmware V6.01.02 and Cox ISP?
Should? I can't say 100% because people have had issues before when changing modems between isp's. But it shoud.
What modem are you upgrading to?
the CM1100 and CM1200 use basically the same chipset and the main benefit is link aggregation. Which I don't consider much of a benefit as many people have issues with link aggregation for stability and speeds.
SushiPragmatic
Apr 15, 2020Tutor
Fingers crossed then that the newer firmware is compatible or that Cox can rollback the firmware.
I am upgrading to the CM1100 and am going to attempt to use link aggregation. If The CM1000 with firmware V6.01.02 will not work with Cox I will just send my family member the CM1100 and keep the CM1000.
- plemansApr 15, 2020Guru - Experienced User
What router are you using with the link aggregation?
Check through some of the forum posts. Not everyone has issues but if you do have issues with the link aggregation, there's quite a few posts with tips/tricks for getting it running better.
- SushiPragmaticApr 16, 2020Tutor
I am actually going to try it with pfsense on a computer I have laying around.
