VSCurtis's avatar
VSCurtis
Using Static IP IP Address
Hi Guys,
I'm currently trying to setup a machine that is connected to my router as a domain controller.  The machine in question is running Windows Server 2008 R2.  The goal here to set the machine up as a VPN Server using SSTP.  In order to setup the domain controller features the machine must have a static IP address.  To that end I reserved the IP address of the machine and also entered the connection information into the machine manually instead of using the automatic setting.  Now that the information is entered do I still need the address reservation entry or can it be removed?  Additionally, will this configuration work for the purposes of installing the other necessary components of the server or are there other factors that need to be dealt with?  I'm trained but my area is software and my network training is limited.  Any help you can provide is appreciated.
  • > In order to setup the domain controller features the machine must have a
    > static IP address.
       Does it need to have a fixed address (static, or reserved dynamic),
    or is a true static address required?
    > [...] To that end I reserved the IP address of the machine and also
       You _can_ do both, of course, but expecting to keep the router's DHCP
    reserved-address table synchronized with a static address on the machine
    itself mau be asking for trouble.  You can do it if you're careful, but
    you'd need to remember that these data are kept in two places (which
    should agree).
       If the machine is configured with a static address, then it might be
    safer to remove the reservation in the DHCP server.  You can have both
    (if you're careful), but you don't need both.
       In either case, I suggest using a static (and/or reserved) address
    which is outside the router's DHCP pool.  (Shrink the pool if it
    occupies all the addresses from ".2" - ".254".)  If the DHCP server is
    smart enough, then it won't issue a reserved address to some random
    client, but it can't see your static address assignment, so, if that
    static address is (still) in the DHCP pool, then there's little to stop
    the DHCP server from issuing it to any random client which asks for an
    address.
    > [...] Additionally, will this configuration work for the purposes of
       My VPN expertise is nil, and I don't know what these "other necessary
    components" might be, so I can't tell you much in that direction.
    • VSCurtis's avatar
      VSCurtis
      Thanks for your help.  It appears that my efforts are in vain.  Even after using address reservation and then entering the reserved address information manually Server 2008 R2 still thinks I'm using a dynamic IP address.  The situation is complicated but the short answer is I'm trying to create a SSTP VPN Server and as such I need a certificate and in order for Server Certificate Authority to function properly the CA must be part of a domain.  I thought I'd try setting up the computer in question as a domain controller then install Certificate Services and the other required compnents needed to complete the VPN Server but it doesn't look like it's going to work
