ryanwagner78's avatar
ryanwagner78
Follower
Nov 19, 2016
Verizon Fios not working with C6300 Modem
I recently purchased a C6300 to replace my standard Verizon modem. I hooked it up, and the Internet Access isn't working. I contacted Verizon and they said they had nothing to do on their end. Does this product work with Verizon, or not? And if so, how? Thanks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ryanwagner78
    The C6300 is a cable modem from what I have read about version fios you need to use there modem for the fiber but can bridge it and you can use your own router if you wanted.
    DarrenM
