MOCCOR
Nov 11, 2024Aspirant
Very bad comcast signal, latency and disconnects. Is it a Comcast problem or a modem/router problem?
Normally I get about 500-600Mbps, but it's been about 5-10Mbps lately. I did a firmware update on my router (Linksys WRT 3200ACM, fresh latest OpenWRT) thinking it might fix/help but it didn't. I had...
- Nov 11, 2024
Power levels are a bit low and maybe some channels are too low:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Seeing lots of correctables and un-correctables that should be mostly zeros like the other channels.
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Nov 11, 2024Guru - Experienced User
MOCCOR
Should I make sure to exclude some specific info? I feel like I read before there is some data in the logs that shouldn't be public, but idk for sure. I can screenshot it np though
- FURRYe38Nov 11, 2024Guru - Experienced User
Redact any MAC addresses please.
- MOCCORNov 11, 2024Aspirant
Time Priority Description
2024-11-11, 12:34:56 Warning (5) MDD message timeout; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
1970-1-1, 00:00:30 Notice (6) Honoring MDD; IP provisioning mode = IPv6
1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 13:47:24 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
1970-1-1, 00:02:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
1970-1-1, 00:02:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:32:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:32:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:28:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:28:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:57 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:57 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:06 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:06 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:00 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:27:00 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:03 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:26:03 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:23:50 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:23:50 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.0; CM-VER=3.0;
2024-10-18, 11:23:47 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
2024-10-18, 11:23:44 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
2024-10-18, 11:23:43 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
2024-10-18, 11:23:00 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
2024-10-18, 11:22:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=[REDACTED]; CMTS-MAC=[REDACTED]; CM-QOS=1.1; CM-VER=3.0;
2024-10-18, 11:22:48 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM- FURRYe38Nov 11, 2024Guru - Experienced User
Ok Ya, lots of Criticals there. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
