Luca333
Sep 17, 2017Aspirant
Very inconsistent upload from 12 to 1 Mbps
Hello guys, I hope I can get some help from some of you, because I'm going nowhere with the xfinity support. I began having very inconsistent upload speed a couple of months ago but now it is ha...
vkdelta
Sep 18, 2017NETGEAR Employee Retired
If the speeds return to normal during evenings, it looks like a capacity issue rathen than Modem issue.
what do you see when you had other modem? same issue?
where are you located?
Have you rented modem from Comcast? if yes, does it show same issue? Sometime, best way to resolve the issue is to rent their modem for few weeks and show the problem to them. At that point, they cannot say, it is modem issue since it is their own modem.
- Luca333Sep 18, 2017Aspirant
Located in Houston.
Same issue with TP link modem and new modem. I didn't think it was a modem issue but I wanted to avoid the "excuse" for comcast to say it is my fault...
