Pravin82
Sep 12, 2015Follower
Very low speed on wifi Netgear C3000
I am using 105 mbps on Xfinity internet. On ethernet cable the speed comes close to 100 mbs, but on wifi its hardly 10 mbps. Comcast is saying this is the issue with my modem. Any suggestion on this ...
DarrenM
Sep 14, 2015Sr. NETGEAR Moderator
Hello Pravin82
You don't happen to have a old 802.11B device connecting to the wireless network because if you do it will drag the whole wifi network down to 11Mbps or slower. If that's not the case I would suggest trying to change your wireless channel to see if that helps some other wifi signals or home appliances could be interfering with your wifi. Hope to hear your feedback.
DarrenM
- RJ007Sep 27, 2015Aspirant
Hello,
I bhought the modem/router- c3700 few days back and am facing the same issue as stated by pravin. i have a comcast connection with a speed of 50 mbps [which is max] and get the same output via ethernet however via wifi i see only 10 mbps. I have an Ipad air and iphone 6 which are connected. Not sure if this will lead to such a severe degradation in wifi speeds [as i dint see this issue with my previous comcast modem/router which i replaced with c3700]. Please suggest if i am missing something to retain my wifi speed to a reasonable limit.
- DarrenMSep 29, 2015Sr. NETGEAR Moderator
Hello Rj007
have you tried both wireless bands to see if this is the case on both the 5ghz and the 2.4ghz?
DarrenM
- RJ007Oct 08, 2015Aspirant
Hello Darren,
Dont mind my delayed responce. And yes both the bands are enabled [for the wifi].
I contacted support and they suggested i use the channels 11 and 161 for 2.5G and 5G respectively and monitor it for 6 hours however i dint see any difference in the wifi speed even though i observed for few days. It just holds standard at 10mbps- does not go up nor goes down. [updated the same to them 3 days back and waiting for a response!]. Wired connection still provides the best experience [upto 60 mbps which is the max i can get].
I browsed through and saw similar syptoms faced by many others with this modem [c3700]. Is there any thing we could do to get the speed up on the wifi [to the expected limit ~40-50 mbps] or returning back is the only option i have :( ?
<< Had very high expectations on Netgear- thought it was The company to provide the best of the Modems>>
