Pravin82
Sep 12, 2015Follower
Very low speed on wifi Netgear C3000
I am using 105 mbps on Xfinity internet. On ethernet cable the speed comes close to 100 mbs, but on wifi its hardly 10 mbps. Comcast is saying this is the issue with my modem. Any suggestion on this ...
RJ007
Sep 27, 2015Aspirant
Hello,
I bhought the modem/router- c3700 few days back and am facing the same issue as stated by pravin. i have a comcast connection with a speed of 50 mbps [which is max] and get the same output via ethernet however via wifi i see only 10 mbps. I have an Ipad air and iphone 6 which are connected. Not sure if this will lead to such a severe degradation in wifi speeds [as i dint see this issue with my previous comcast modem/router which i replaced with c3700]. Please suggest if i am missing something to retain my wifi speed to a reasonable limit.
DarrenM
Sep 29, 2015Sr. NETGEAR Moderator
Hello Rj007
have you tried both wireless bands to see if this is the case on both the 5ghz and the 2.4ghz?
DarrenM
- RJ007Oct 08, 2015Aspirant
Hello Darren,
Dont mind my delayed responce. And yes both the bands are enabled [for the wifi].
I contacted support and they suggested i use the channels 11 and 161 for 2.5G and 5G respectively and monitor it for 6 hours however i dint see any difference in the wifi speed even though i observed for few days. It just holds standard at 10mbps- does not go up nor goes down. [updated the same to them 3 days back and waiting for a response!]. Wired connection still provides the best experience [upto 60 mbps which is the max i can get].
I browsed through and saw similar syptoms faced by many others with this modem [c3700]. Is there any thing we could do to get the speed up on the wifi [to the expected limit ~40-50 mbps] or returning back is the only option i have :( ?
<< Had very high expectations on Netgear- thought it was The company to provide the best of the Modems>>
- DarrenMOct 08, 2015Sr. NETGEAR Moderator
Hello RJ007
I know you said you had 2 apple devices that are connecting to the wifi but have you tried a speed test on a laptop to see if you get the same results as the apple devices. Im trying to figure out if it may be the router having a issue with communicating with apple devices or if its the wifi.
DarrenM
Darren,
I did not try a speed test on my apple devices until now and was performing speed test only on my laptop [~10mbps]. However currently i did the speed tests on both the laptop and iphone multiple times and got the following results:
On WIFI [the speeds were slightly up compared to earlier instances but still low compared to the actual speed expected]-
Iphone: 19 mbps
Laptop [hp/windows]: 14 mbps.
Wired-
Laptop: 59-60 mbps
