techlover1
Mar 22, 2017Follower
Very poor customer service in support of wifi router not performing!
I just called for the first time to request support for an issue I have with my wifi which is supposed to work up to 300Mbps, I'm getting 100Mbps from the cable company but when it goes over wifi I j...
schumaku
Mar 25, 2017Guru - Experienced User
An N300 router does never ever reach the theoretical data rate of 300 Mb/s - realistic numbers for N300 on 2.4 GHz band on short distances are some 50..20 Mb/s effective, becoming less on a distance, through walls, ...
Depending on the distance, the environment, the WiFi client in your computer, the numbers are highly variable.
-Kurt
