blissintampa
Jun 10, 2017Aspirant
Very slow and losing wifi connection on 2.4 ghz. 5 ghz works fine and so does hard wired.
I had a power outage a bit over a week ago. After that I was having a hard time staying connected to the wifi. I thought something may have been damaged due to the power outage so I exchanged it for ...
DarrenM
Jun 13, 2017Sr. NETGEAR Moderator
Hello blissintampa
With spectrum being multiple company coming together they are not on the same page for firmware in all areas that may be why yours is older. As for the wireless have you removed old networks wireless network settings saved in your devices? You mentioned getting a new unit your wireless devices could be trying to use some old wifi settings and its causing conflicts.
DarrenM
- blissintampaJun 13, 2017Aspirant
Thanks for responding. I have had all my devices that will allow to "forget" the old connection. The reason I got a new unit was because Best buy thought my power outage may have damaged something in the old unit. Up until the power outage it worked excellent. I have my tablets and sons Playstation 4 connected to 5ghz and they are not having any issues staying online. I had to end up buying a 50 ft ethernet cord to get internet on my desktop. I was told by Netgear that there is signal interference on 2.4ghz. That it is caused by too much network traffic (I live in Tampa, FL with lots of neighbors). Now their option for me is to either buy a new modem and router seperate or bridge the one I have and buy another router. I would just return this one but the original one I bought is over 90 days old and the one I have now is from a warranty I purchased separately. I don't want to spend a ton of money on modems and routers. I just want one that stays working lol. There aren't many options Spectrum gives you on modems/routers you can use. The reason I purchased my own is because I was renting one of theirs and it would disconnect like 50 times a day and said there was nothing wrong with it or my lines.
