pmb1976
Dec 21, 2024Aspirant
Very slow Internet Download Speeds even after Xfinity repairs in my area
Even after Xfinity completed repairs in my area for performance related issues and even though I worked with Xfinity support, I continue to get extremely slow internet download speeds (about 10-20% o...
Kitsap
Dec 21, 2024Master
Recommend you use the installable Ookla stand alone application to measure throughput. It appears you are using a web browser and the Ookla web address. This later approach introduces inaccuracies based on the web browser.
The application is available in the Microsoft store or the play store.
What is the brand name and model number of the router you are using?
What device are you running the web browser on for testing?
pmb1976
Dec 22, 2024Aspirant
Hi,
The speed tests are run using the Ookla provided command line tool. I've run speed test using the Ookla application with similar results. I've been running periodic automated speed test for several years (see graphs for what I mean) without issue.
The cable modem is a Netgear CM1000.
