BZpbp
Sep 26, 2017Tutor
Voice calls cutting out
Voice calls keep cutting out intermittently....not a total drop...sometimes I hear just fragments of words coming from the other end. Seems to get better after power cycle...but a couple of hours la...
DarrenM
Sep 28, 2017Sr. NETGEAR Moderator
Hello BZpbp
Have you checked with you ISP have them check everything on there side?
DarrenM
BZpbp
Sep 29, 2017Tutor
Yes...all checked out....in fact, they installed a voice only modem, and there were no issues. When I went back to 7100V...calls cut out. there must be a conflict somewhere interfering with voice calls
- DarrenMOct 02, 2017Sr. NETGEAR Moderator
We want to work with you on this send me a PM with your name, email, and phone number and our support team will contact you.
Thanks
DarrenM
- pdxbearsOct 15, 2017Aspirant
I have the same problem with my c7100v. Very frustrating. Comcast says everything looks fine.
- BZpbpOct 16, 2017Tutor
Yes....same thing here...I have now given up on using the 7100v for voice...comcast installed a separate voice modem, and I haven't had a problem since. There is some issue with the 7100v voice setup....I don't have the time to figure it out.
