BZpbp
Sep 26, 2017Tutor
Voice calls cutting out
Voice calls keep cutting out intermittently....not a total drop...sometimes I hear just fragments of words coming from the other end. Seems to get better after power cycle...but a couple of hours la...
BZpbp
Sep 29, 2017Tutor
Yes...all checked out....in fact, they installed a voice only modem, and there were no issues. When I went back to 7100V...calls cut out. there must be a conflict somewhere interfering with voice calls
DarrenM
Oct 02, 2017Sr. NETGEAR Moderator
We want to work with you on this send me a PM with your name, email, and phone number and our support team will contact you.
Thanks
DarrenM
- pdxbearsOct 15, 2017Aspirant
I have the same problem with my c7100v. Very frustrating. Comcast says everything looks fine.
- BZpbpOct 16, 2017Tutor
Yes....same thing here...I have now given up on using the 7100v for voice...comcast installed a separate voice modem, and I haven't had a problem since. There is some issue with the 7100v voice setup....I don't have the time to figure it out.
