Packfan95
Sep 28, 2021Aspirant
VPN capable Cable Modem Router
This is more of a questions for the community if these even exsist. I'm looking for a cable modem router that has VPN capabilites as an all in one package. Ive been looking through forums and articl...
Sep 28, 2021Guru - Experienced User
What type of vpn are you planning on using? Some of them require their own firmware be installed to truly be a vpn. modem/router combo devices don't allow this function because of the docsis spec.
Packfan95
I use NordVPN right now. But i beleive my promo for 3$/month is expiring soon
- plemansSep 28, 2021Guru - Experienced User
VPN's that function on router level usually (haven't found any that don't) require their own firmware/ddwrt on the router.
Some routers support it out of the box. But i havent seen any from netgear that do.
If you're planning on using a VPN, I'd recommend getting a router seperate from the modem. Otherwise the ISP controls the firmware and you can't install your own to it.
