broger
Feb 26, 2021Follower
VPN Connection not working.
When I try to connect to work server VPN I get the following error message. The network connection between your computer and the VPN server could not be established because the remote server is ...
michaelkenward
Feb 27, 2021Guru - Experienced User
VPNs can be messy to get right. It might help if you told people which one you are using. Have you asked them for help?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
