Devilsbane
Nov 06, 2016Tutor
VPN into home network with C7000
I bought the C7000 recently, which I believed was an R7000 paired with a cable modem. Works great and I get excellent speed. I saw that the R7000 is able to set up a vpn server, but the c7000 seems t...
DarrenM
Nov 09, 2016Sr. NETGEAR Moderator
Hello Devilsbane
Not possible on the C7000.
DarrenM
JohnnyNash
Nov 30, 2016Aspirant
Hello, I also have this question and thanks for the answer. Is there any type of alternative we can use? I am a newby with routers and just want to make it a little more secure since I run my business through it
- DarrenMDec 02, 2016Sr. NETGEAR Moderator
Hello JohnnyNash
you may have to look into business routers if you are trying to do a VPN server but home routers can be used as clients.
DarrenM
