CharlesK25
Feb 25, 2022Aspirant
VPN Issues - Double NAT - AC1600 C6250 Router
I have been unable to connect to my company's VPN for approximately three weeks while using the same router and devices for months. I performed a factory reset to my Netgear AC1600 router/modem with ...
Feb 25, 2022Guru - Experienced User
I have talked to your company's vpn provider?
Maybe they require specific port forwarding.
CharlesK25
Thanks for the reply. I am able to access the vpn on other networks including my verizon hotspot. All settings are accurate to connect to the VPN on the devices. I have partnered with our IT department and they are saying the issue is specific to my router and the double nat issue.
- plemansFeb 25, 2022Guru - Experienced User
try setting the device you're using in netgear's dmz.
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
- CharlesK25Feb 25, 2022Aspirant
Would this create a security issue as the device would essentially have limited firewall protection?
Also, I went into WAN Settings and set the DMZ to the ip address my Dell Latitude was on and still unable to connect to the VPN with same error message.
I'd be checking with your work vpn provider. With the IP address set in the wan, ALL traffic is forwarded. so there's nothing blocking/firewalling.
