timharmer
Sep 24, 2020Aspirant
WAC 124 No internet
I set up my WAC124 in Access point mode absolutely fine. Next day I just turned it off and on to try and get a google home working with it. Now, it is not detecting the internet cable in the back. I ...
- Sep 24, 2020
Currently i think i have fixed it. I just plugged it into a different LAN outlet on the router and it seemed to fix it. Not sure what went wrong but fingers crossed it will stay fixed. such a pain though
timharmer
- FURRYe38Sep 24, 2020Guru - Experienced User
Be sure to post in the following forum for your model product:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
