lsfinn99
Aug 14, 2023Aspirant
WAN accessibility cut-out at 18:01 MT every night
An ISP (xfinity) service tech checked and confirmed the signal and line quality UP to the modem is in spec.
An ISP service tech re-provisioned the modem.
Per the ISP service tech there are no l...
Aug 22, 2023Guru - Experienced User
Any progress on this?
What NG product model are you referring too?
lsfinn99 wrote:
- An ISP (xfinity) service tech checked and confirmed the signal and line quality UP to the modem is in spec.
- An ISP service tech re-provisioned the modem.
- Per the ISP service tech there are no line splitters, amps, or attenuators between the modem and ISP service box.
- Two different ISP service techs separately replaced the RG6 coax cable up to the modem.
- The cable is in-wall; so, there is no way to check for kinks, damage, or moisture in the line (other than checking signal levels).
- The ISP service techs checked the connector ends.
- I have disconnected the modem from the power for over 1 minute and powered back on with no change in the symptomology.
Let me note again three salient aspects of this failure:
* The cut-off occurs regularly at a very specific time (18:01 MT) each PM. Over the last several days I've confirmed that the AM cut-off occurs regularly at 6:00 MT (i.e., no mail from icloud or my business server is received after 6:00 AM MT); and
* The cut-out is only partial: the xfinity web site is accessible, and generally (but not always) google is accessible. Sometimes a few other web sites (e.g., local community newspaper) remain accessible; however, almost all others - including biggies (nytimes.com, washingtonpost.com) - time-out;
* Prior to my changing DNS servers I was unable to recover WAN connectivity, with or without a modem reboot, until morning (generally between 8:00 - 9:00) when a modem reboot would recover WAN connectivity. After changing DNS servers I am generally able to recover connectivity after a modem reboot.
While appreciated, generic suggestions that do not recognize or acknowledge the particular details of the failure I'm experiencing - especially those highlighted above - are unlikely to be helpful.
- lsfinn99Aug 22, 2023Aspirant
The product is the CAX80 cable modem router.
- FURRYe38Aug 22, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- lsfinn99Aug 22, 2023Aspirant
Equipment: Netgear CAX80 modem/router. Hardware version 1.01, Firmware version V2.1.5.2; Cable Firmware Version V1.02.08. The modem is provisioned by Comcast/xFinity.
Attached PDF is built from screen grabs of cable connection info (first 7 pages) followed by event log (last 4 pages)
