lsfinn99
Aug 14, 2023Aspirant
WAN accessibility cut-out at 18:01 MT every night
An ISP (xfinity) service tech checked and confirmed the signal and line quality UP to the modem is in spec.
An ISP service tech re-provisioned the modem.
Per the ISP service tech there are no l...
lsfinn99
Aug 22, 2023Aspirant
The product is the CAX80 cable modem router.
Aug 22, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- lsfinn99Aug 22, 2023Aspirant
Equipment: Netgear CAX80 modem/router. Hardware version 1.01, Firmware version V2.1.5.2; Cable Firmware Version V1.02.08. The modem is provisioned by Comcast/xFinity.
Attached PDF is built from screen grabs of cable connection info (first 7 pages) followed by event log (last 4 pages)
- FURRYe38Aug 22, 2023Guru - Experienced User
Power looks good.
I see lots of correctables on the one Up channel. Wondering if this should be zeros here.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Especially T3s.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
