Gowired
Jul 09, 2019Aspirant
Wanting to escape from Wi-Fi EMFs for health reasons
I would like some advice please ( I am an intelligent 70 yr old, but not very tech-savvy ). At the moment at home I have TalkTalk wi-fi router serving the rooms in my house well. But I want to go...
Jul 09, 2019Guru - Experienced User
Any Nighthawk R series router maybe good for you. You can disable the WiFi radios as needed.
https://www.netgear.com/home/products/networking/wifi-routers/
Check out the R7800...
Please post more about this in this forum if you need more help regarding the R series routers:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
This is a cable modem gatway router forum.
Gowired
Thanks very much for your informative reply. The Netgear R series ( including R7800) look extremely good. But for my own fairly modest needs ( small household, not into gaming etc ) I wonder if there are any less expensive routers - which have an on/off WiFi button ?
- FURRYe38Jul 10, 2019Guru - Experienced User
The R7000 would probably be best suited for your needs. I believe it has a wifi ON/OFF button on top for easy access. I know the R7800 does.
Good Luck.
