scootley's avatar
May 09, 2024
Web admin interface does not respond when modem loses downstream link (CM500)
Hi,
I have a CM500 cable modem.  It has an administrative web interface at http://192.168.100.1/
It is connected to a router.
I've noticed that when my ISP has an outage, the administrative web interface fails to load and the modem cannot be pinged (with a command-link ICMP ping tool).  For example recently the modem indicated (via the lights) that it lost the downstream (and upstream) link, and during that time I could not view the web interface.
When it comes back online with the ISP, the web interface works fine and it can be pinged.
Is this normal?  Was it designed this way on purpose?  Why?
In case it is unclear, I am not asking for help with my ISP connection being down.  I am asking only about why I cannot view the modem's admin interface 100% of the time when it is turned on, regardless of whether it has an ISP connection or not.
I guess there is a chance that my router is somehow failing to route packets to the modem during this scenario, but I have not investigated this too much.
I should add that this seems to have been happening since I got the modem several years ago.  It is a consistent issue and not new.
Thanks
  • FURRYe38's avatar
    Possible that the ISP puts something with in the config file to not allow access. I wouldn't put it past an ISP to do something like that. Depends I guess.
    I presume if you disconnected the ISP coax cable line, can you access the modems web page? Even if you factory reset it?
    Most modem side issues are handle at the ISP level. Not much can be changed or is known for CM series modem since there FW is updated by the ISP and can't be by users. The way it is for C and CM series modems.
    • scootley's avatar
      scootley
      Tutor
      Thanks FURRYe38
      So netgear allows ISP firmware to somehow configure or control access to the web interface?  That is very strange but I guess if it's known that this is possible then sure.  Is there a known precedent for that where someone else has seen it happen?
      We use the term "firmware" with cable modems sometimes as if it is monolithic.  Is it?
      Specifically, does the ISP have the ability to send a new or tweaked version of 100% of the firmware that runs on the modem?  Could the ISP create their own custom admin web interface and replace the existing one?  Or is there a component of the firmware that is fixed and not updatable by the ISP?
      Or conversely, if it really is monolithic, does the ISP have to distribute the code (binary) for the admin web interface back to the modem every time they do an update involving "normal ISP stuff" (like I dunno the channel bonding configuration) even though they don't want to change the web interface?  Does netgear give these web interface binaries to the ISP so they can be redistributed during an update?
      I have not tried doing a factory reset and disconnecting the coax and trying the web interface but if I can find a good time to do that, I will.
      What series of modems (since not C and CM) allow better firmware management and/or user updates?
      • FURRYe38's avatar
        scootley wrote:
        Thanks FURRYe38
        So netgear allows ISP firmware to somehow configure or control access to the web interface? Anything is possible with some ISPs.
        That is very strange but I guess if it's known that this is possible then sure.  Is there a known precedent for that where someone else has seen it happen? Seen this posted before with some ISPs. Not sure why. Most major ISPs don't do anything with user own modems. Only update FW. For some ISPs, they won't even update FW on user own modems connected to there services. NG develops the FW, then hands it off to the ISP for there testing and certification on there services, once they approve and certify  it, then the ISP can push to modems.
        We use the term "firmware" with cable modems sometimes as if it is monolithic.  Is it? It is the operating system that modems run on. Won't with out it.
        Specifically, does the ISP have the ability to send a new or tweaked version of 100% of the firmware that runs on the modem?  Yes. Could the ISP create their own custom admin web interface and replace the existing one?  Possible. Or is there a component of the firmware that is fixed and not updatable by the ISP? No.
        Or conversely, if it really is monolithic, does the ISP have to distribute the code (binary) for the admin web interface back to the modem every time they do an update involving "normal ISP stuff" (like I dunno the channel bonding configuration) even though they don't want to change the web interface?  Does netgear give these web interface binaries to the ISP so they can be redistributed during an update? Possible
        What series of modems (since not C and CM) allow better firmware management and/or user updates? CAX series which are gateway modem an FW that is user updateable is the router portion of the modem. The modem is still handled by the ISP.
