hbhansen
Aug 22, 2022Aspirant
Website white screen
When trying to login to my Nighthawk CAX30 router via http://routerlogin.net, after successfully entering my user name and password, all I get is a white screen (see attachment); no tabs, no menus, n...
Aug 22, 2022Guru - Experienced User
Along with Kitsap you can try a different pc. Could be a device specific issue
- hbhansenAug 23, 2022Aspirant
Tried logging in from another PC- no difference; still just a white screen.
- plemansAug 23, 2022Guru - Experienced User
Is the CAX working? are you able to get online?
did you try simply factory resetting it?
- KitsapAug 23, 2022MasterDon't know if a pardon is necessary, but a correction was certainly warranted.
Maybe the firmware on your CAX80 has been corrupted. Only your ISP can re-flash your firmware unless the modem/router has separate firmware.- plemansAug 23, 2022Guru - Experienced User
Have you tried the 192.168.100.1 address? I've randomly found that worked with my CAX when the routerlogin address was failing to load.
