BringBackDOS
Jan 15, 2017Follower
What are the differences Between the R6250 and the C6250 Cable / Modem / Routers?
What are the differences Between the R6250 and the C6250 Cable / Modem / Routers? I'm shopping for a New Cable Modem so as to circumnavigate TWC's Monthly Cable Modem Fees. I have one picked out but ...
michaelkenward
Feb 04, 2017Guru - Experienced User
R6250 is a router, no modem.
Some modems can work as "modem only". But even you can do it with the C6250 it has only two LAN ports on the back.
What is it that you want to achieve?
