ensignsid
Aug 21, 2020Aspirant
What are your download speed for Netgear CM1150V?
I would like to know the kind download speeds people are getting with this modem (CM1150V). I'm getting ~500 mbits with a 1G plan.
Is that directly connected to the modem?
What device are you testing on?
What website are you testing with? if its speedtest.net make sure to try different servers.Do you have a screen snip of the cable connections page?
- ensignsidAspirant
I just want to see what downlaod speeds people are getting. Ideally right after the modem, but I'll take what ever people are getting. I'm deciding whether to keep my CM11150V or return it. And yes, Comcast tech gets 1G off my cable line.
the cm1150v should easily hit gigabit on comcast
Be sure to test with a wired PC. If your on a 1G plan you should see near 900Mpbs with a wired PC.
- astnmartin23Aspirant
Hello,
To actually answer your question: I have this modem and I'm getting around 930 Mbps from both being directly wired and being wired through a Netgear router. I have the Xfinity 1Gbps plan.
They've recently upped the speed for that plan from 1000Mbps to 1200Mbps but I haven't seen any speed increase since that.
- RedsonRisingAspirantHave you rebooted the modem since the speed upgrade?
