jasonrdavis
Aug 04, 2017Aspirant
What does a flashing green upstream light mean on the CM500 modem?
I am troubleshooting a problem with my CM500 cable modem where the Internet sporadically drops or partially drops. What does a flashing green upstream light mean? I have looked in Netgear's offi...
vkdelta
Aug 05, 2017NETGEAR Employee Retired
are you sure you captured this exactly when US lights were flashing or after sometime?
the screenshots show Upstream channels are ok.
jasonrdavis
Aug 05, 2017Aspirant
My apologies, I posted the wrong screenshot. It is flashing green right now (all others are solid green), and the Internet light is also flashing green. This is what I see:
- vkdeltaAug 05, 2017NETGEAR Employee Retired
we cannot see screeshot. Please post again and capture exactly when the problem is seen.
also, post event logs.
- jasonrdavisAug 07, 2017Aspirant
Time Priority Description 2017-8-7, 03:49:25 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 03:49:39 Warning (5) Dynamic Range Window violation 2017-8-7, 04:02:52 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:48:03 Warning (5) Dynamic Range Window violation 2017-8-7, 06:48:19 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:48:20 Warning (5) Dynamic Range Window violation 2017-8-7, 06:48:34 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:48:35 Warning (5) Dynamic Range Window violation 2017-8-7, 06:48:49 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:49:03 Warning (5) Dynamic Range Window violation 2017-8-7, 06:49:19 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:49:20 Warning (5) Dynamic Range Window violation 2017-8-7, 06:49:34 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 06:49:48 Warning (5) Dynamic Range Window violation 2017-8-7, 08:35:28 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:35:28 Warning (5) Dynamic Range Window violation 2017-8-7, 08:35:43 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:36:11 Warning (5) Dynamic Range Window violation 2017-8-7, 08:36:27 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:36:41 Warning (5) Dynamic Range Window violation 2017-8-7, 08:42:41 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:42:42 Warning (5) Dynamic Range Window violation 2017-8-7, 08:42:56 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:47:54 Warning (5) Dynamic Range Window violation 2017-8-7, 08:48:40 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 08:49:39 Warning (5) Dynamic Range Window violation 2017-8-7, 09:16:19 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:21:17 Warning (5) Dynamic Range Window violation 2017-8-7, 09:21:33 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:21:34 Warning (5) Dynamic Range Window violation 2017-8-7, 09:21:48 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:22:17 Warning (5) Dynamic Range Window violation 2017-8-7, 09:22:33 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:22:47 Warning (5) Dynamic Range Window violation 2017-8-7, 09:23:18 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:24:32 Warning (5) Dynamic Range Window violation 2017-8-7, 09:33:16 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:33:30 Warning (5) Dynamic Range Window violation 2017-8-7, 09:33:46 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; 2017-8-7, 09:34:15 Warning (5) Dynamic Range Window violation - DarrenMAug 10, 2017Sr. NETGEAR Moderator
Hello jasonrdavis
Do you happen to have the modem connected with a splitter on it you may want to remove it if so see if the modem improves if not you may want to have the ISP send someone to check your lines.
DarrenM
