jasonrdavis
Aug 04, 2017Aspirant
What does a flashing green upstream light mean on the CM500 modem?
I am troubleshooting a problem with my CM500 cable modem where the Internet sporadically drops or partially drops. What does a flashing green upstream light mean? I have looked in Netgear's offi...
vkdelta
Aug 05, 2017NETGEAR Employee Retired
we cannot see screeshot. Please post again and capture exactly when the problem is seen.
also, post event logs.
jasonrdavis
Aug 07, 2017Aspirant
| Time | Priority | Description |
| 2017-8-7, 03:49:25 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 03:49:39 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 04:02:52 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:48:03 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 06:48:19 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:48:20 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 06:48:34 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:48:35 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 06:48:49 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:49:03 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 06:49:19 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:49:20 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 06:49:34 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 06:49:48 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:35:28 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:35:28 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:35:43 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:36:11 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:36:27 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:36:41 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:42:41 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:42:42 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:42:56 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:47:54 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 08:48:40 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 08:49:39 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:16:19 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:21:17 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:21:33 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:21:34 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:21:48 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:22:17 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:22:33 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:22:47 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:23:18 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:24:32 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:33:16 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:33:30 | Warning (5) | Dynamic Range Window violation |
| 2017-8-7, 09:33:46 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:ef:ed:c0;CMTS-MAC=00:1e:be:fe:d6:8d;CM-QOS=1.1;CM-VER=3.0; |
| 2017-8-7, 09:34:15 | Warning (5) | Dynamic Range Window violation |
- DarrenMAug 10, 2017Sr. NETGEAR Moderator
Hello jasonrdavis
Do you happen to have the modem connected with a splitter on it you may want to remove it if so see if the modem improves if not you may want to have the ISP send someone to check your lines.
DarrenM
- jasonrdavisAug 10, 2017Aspirant
Nope, no splitter.
A Cox technician came out again today and is going to put in a work ticket for a supervisor to come out, and examine the closest upstream junction point (or something).
