duckware
Oct 18, 2021Prodigy
What does "CCAP Commanded Power in Excess of 6 dB Below..." mean?
"RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW" means exactly what? Often seen with "Dynamic Range Window violation" and "Started Unicast Maint...
- Jun 28, 2022
Finally, after a ton of tech visits, the ultimate problem causing this issue has been found: A bad cable from the top of the telephone pole (at the tap) running 15' to the base of the telephone pole (ground block). For full details (and more), visit: https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
B-Kat
Oct 05, 2023Aspirant
just wanted to thank you as I finally fixed my internet drops after months of trying thanks to you and that PDF/article you put together and posted. I was getting 20-30 drops (each 3-10 seconds) a day and I came across your post and noticed your logs/error codes looked identical to mine. I had the ISP techs out several times, which turned out to be worthless, so I read your entire troubleshooting article and ended up finding the issue and fixed it myself! Thanks!!! đ
