JGs3
Jun 13, 2020Follower
What internet provider speed can nighthawk C7000V2 handle
Hey all, Essentially Cox is telling me that my C7000V2 Nighthawk is not compatable with their 500MBPS internet package because it is to slow. The only reason I want this package is it is 40-30$ ch...
michaelkenward
Jun 14, 2020Guru - Experienced User
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
The datasheet will tell you more.
If you need more specific information, you might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Cable Modems & Routers
Cox seems to have approved FW for the C7000 series gateway modems:
