gburns53
Nov 12, 2020Aspirant
What is Native Ipv6 and what does it mean for your modem purchase and ISP?
I think a lot of people are confused why Ipv6 works/doesn't work. I can't get it working and my ISP can't help me. I understand my modem is considered pass-through. I'm not sure exactly what that mea...
gburns53
They seem to think they can support Ipv6 to some extent. (And it may be simply turning on a tunneling feature in their Modems)
My google wifi mesh system and app says something very clear, like "Ipv6 is now enabled, but Ipv6 is not configured or is not supported by your ISP. So everything is using IPv4.
When I say "WOW!, please help me I can't get it active.." they say "sure, we can do that!"... Then they take a look at my modem remotely.. and then they realize it's a personal modem and tell me to contact Netgear.
It's very much as if they want to flip a switch for me in the software settings.. but they can't do it because it's not their modem. I've asked them, what do you want me to do? I can see all the options (there's almost 0, btw) in the admin config. But they just keep saying talk to your manufacturer. I've talked to 3 different people at WOW! and I got pushy looking for answers, this leads me to believe there's a confusion factor happening.. and I highlighted that confusion above with what I think the reason might be.
Nov 12, 2020Guru - Experienced User
There would be nothing in the NG modem to configure. You can check to be sure at 192.168.100.1. However I believe it's all pass thru.
Next you would need to make sure your external router is configured correctly to receive IPv6 protocols from the ISP thru the modem...
- gburns53Nov 12, 2020Aspirant
Google wifi app makes it very clear the problem is occurring in the ISP/Modem end. Yes, I get that there's nothing to change in the Config for this modem.. trust me I relayed this to my ISP.
Yet again, the place where we need to place our finger (the solution) is why my ISP thinks they can solve this problem if I was renting one of their modems.
- FURRYe38Nov 12, 2020Guru - Experienced User
So, connect up a wired PC to the CM modem. Remove the external router. WIth your PC you can tell if IPv6 is coming thru ether in the networking status section or in a command line by using IPCONFIG /ALL
