SanCorreia
Feb 17, 2023Follower
What is the best router modems
I have a 6 years old netgear device and it's time to upgrade. So does anyone can recommend the best choice for new modem router up to 1 tb
1 Reply
"up to 1 tb?"
Do you mean gigabit?
I'd recommend buying a modem separate from the router. That way you can always upgrade one without needing to buy a whole combo unit.
But if you have to the CAX80 and CAX30 are pretty solid modem/router combo devices
