kdegru
Oct 03, 2015Aspirant
What is the boot or startup sequence for a CMD31T cable modem?
I have a unit that was given to me and I kept it on the shelf just in case. Well now I have to swich my internet provider and it will be a cable provider and I wanted to use this modem if it works t...
DarrenM
Oct 06, 2015Sr. NETGEAR Moderator
Hello kdegru
You should see the power light when plugged in and maybe 1 light blinking without a Internet connection once a cable connection is hooked up it should blink and go solid and move on to the next light and it will blink and then go solid until they all do to show it has a connection.
DarrenM
kdegru
Oct 10, 2015Aspirant
DarreM: Thanks for the confirmation about the startup routine on a CMD31T cable modem. It seems I was unlucking in buying a used unit that will not boot up. I took a chance thinking only a new power adapter would be needed but sadly this like new modem is truly dead and will not boot.
