davbott
Oct 27, 2024Follower
What is the maximum satellites supported by a CBR750?
I currently have a CBR750 with two satellites registered. An RBS750 and an RBS750P, both attached to my home network via ethernet. All is healthy. Is it possible to add an RBR750P as a satellite...
Oct 28, 2024Guru - Experienced User
You put that you're trying to sync the RBR750 with the CBR.
If its an RBR aka router, it won't work as a separate satellite from the cbr.
you could add it as an access point but not as part of the mesh.
- CrimpOnOct 28, 2024Guru - Experienced User
Totally correct. I read the question incorrectly. (and went off on a wild tangent.... sorry)
