HSCB's avatar
HSCB
What is the optimum internet speed subscription for the CAX30S?
  • plemans's avatar
    Who's your isp and what speeds are you looking for?
    There isn't an "optimum speed" because the optimum for you might not be the same for others
    • HSCB's avatar
      HSCB
      We have xfinity at 200 mps for movies and web use only. Do I need more or less?
      • plemans's avatar
        the CAX30 should easily handle those speeds.
        If you're needing faster speeds, you can always upgrade your service and the CAX is capable of it.
