scv16
May 15, 2020Tutor
What is the right firmware version for the CM1100 on Xfinity/Comcast?
According to the following page, the right firmware version for CM1100 and Xfinity/Comcast is V2.01.02: https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-mod...
scv16
May 15, 2020Tutor
Yeah, understood that the firmware comes form the ISP. However, the Netgear article states V2.01.02 is the current firmware that Comcast delivers for CM1100. This does not match what I am getting for my modem, which is v6.01.07. So either the Netgear KB article is wrong and should be updated or Comcast is delivering the wrong firmware to my modem.
May 16, 2020Guru - Experienced User
ISPs can and do update modem FW as well. So regardless of the information on NG site, maybe out of date or inaccurate.
Is the modem working? Of so, then you'll be fine.
- scv16May 16, 2020Tutor
Thanks FURRYe38, makes sense.
Things are actually not working well. I've been having consistent connectivity issues since upgrading to Xfinity Gigabit and the Netgear CM1100 modem. We've been going through a process of troubleshooting this. It appears we have short connectivity issues that correlate to "MDD message timeout" warnings in the logs. These warnings are in the logs throughout the day and can cause more significant issues when clustered closer together in time. Typically this manifests in buffering video or choppy Zoom conferences.
To date we've replaced all lines and connections from the pole to the house, removed all splitters and verified that power and SNR ratios are generally good.
So, I'm still at a loss for the cause of the MDD message timeouts and why this may cause connectivity issues. The firmware question was grasping at straws. One other oddity in the Netgear CM1100 logs is they appear to be off by an hour, not sure if this could cause a problem.
Any guidance or tips ere would be helpful.
Thanks!
