Podnumber1
Feb 19, 2025Follower
What is the size of the barrel power connector on RAXE500
I would like to know so I can make a dc connector for backup battery / mini ups. Thank you
- Feb 19, 2025
Or just pickup a standard ups that the power brick plugs into. Tends to be cheaper and work better.
Feb 19, 2025Guru - Experienced User
Power Adapter Replacements:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBKE960-power-adapters-needed-or-model-number-for-power-adapter/m-p/2375651/highlight/true#M55073
RAXE500 - http://www.winco.com.hk/
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/RAXE500-power-adapter-replacement/m-p/2338224/highlight/false#M35375
https://www.amazon.com/Kircuit-Compatible-332-11588-01-3321158801-PY321200536/dp/B0CH3FW3HS
https://www.amazon.com/CASIMY-Compatible-Quad-Band-AXE11000-Nighthawk/dp/B0CNVKD1KF/ref=dp_fod_sccl_3/144-3727805-5531002
