WTFWWIW
Jul 31, 2019Tutor
What is using my data?
Hi, I have been on the phone to comcast and they tell me that they can't give me a breakdown of my internet usage because I am using a netgear router and modem. If I was using their xfi equipment I w...
Aug 01, 2019Guru - Experienced User
What NG product model do you have?
Try using Traffic Meter if it's supported on your NG product. This only gives a over all useage thru the router. Doesn't track anything to a specific device.
WTFWWIW
Aug 03, 2019Tutor
Thanks for the reply look for link to specific device and time on usage apparently this is all avaliable to you if you rent gear through comcast so can't believe this is a gap that netgear hasn't addressed?
I have a CM1000 and R6300. Thanks!
- WTFWWIWAug 03, 2019Tutor
Also, an EX7000
