JohnnieWalker22
Aug 26, 2021Guide
What would be the best setup of a Nighthawk CAX30 and Nighthawk MR60 with the Two Sattelites?
Hello, As the title says, what would be the best way to set both of these up? Have a one gig speed plan with Xfinity. CAX30 is currently in one side of the house which means the other side has dead ...
- Aug 26, 2021
Configure the CAX30 for modem mode only. Then use the MR series has the main router and wifi system.
Aug 26, 2021Guru - Experienced User
JohnnieWalker22
Aug 27, 2021Guide
This worked wonders! Thanks!!
- FURRYe38Aug 27, 2021Guru - Experienced User
Enjoy.
