JohnnieWalker22
Aug 26, 2021Guide
What would be the best setup of a Nighthawk CAX30 and Nighthawk MR60 with the Two Sattelites?
Hello, As the title says, what would be the best way to set both of these up? Have a one gig speed plan with Xfinity. CAX30 is currently in one side of the house which means the other side has dead ...
- Aug 26, 2021
Configure the CAX30 for modem mode only. Then use the MR series has the main router and wifi system.
JohnnieWalker22
Aug 27, 2021Guide
This worked wonders! Thanks!!
Aug 27, 2021Guru - Experienced User
Enjoy.
